Petit vidéo trouvée sur Facebook
Faites votre barre-led-qui-déchire-la-nuit vous même
https://www.truenorthsupplydrop.com/products/100w-9200-lumen-led-chips
La liste des composants :
Lenses: http://amzn.to/2kWRCo8
Resistors: http://amzn.to/2mi05Tr
We recommend using Boost converters to drive the LED's from 12v or so (No resistors, one per chip, can also drive the cooling stuff with the same 12v): http://amzn.to/2kWH7l6
Cooling Blocks: http://amzn.to/2lb2gmN
Tubing: http://amzn.to/2moToM7
Pump: http://amzn.to/2lGTb8z
Super neat pump/reservoir combo (much easier than hacking a bottle and much less likely to leak..): http://amzn.to/2lbas6h
Heat Exchanger: http://amzn.to/2lb0WA6
Batteries (3): http://amzn.to/2laNpZC (connect in series for direct drive w/ resistors, connected in Parallel for 12v system with boost converters)
Super simple LiPo Charger: http://amzn.to/2kWImR3
Thermal Glue: http://amzn.to/2mwylXb
