salut wiec,
voici quelques combinaisons possible pour faire quelques "stroker":
Stroker combinations
I've outlined ten stroker combinations below based on budget and desired horsepower levels. To get maximum benefit from the stroker engine you need a free-flow intake with Powerstack or K&N cone filter, 62mm bored HO throttle body, header, high-flow cat, performance muffler and 2.5" exhaust piping.
4.5L "Poor man's" simple stroker
~ Jeep 4.2L 3.895" stroke crank
~ Jeep 4.2L 5.875" rods
~ Speed Pro 677P standard bore pistons
~ 9.05:1 CR
~ Stock 4.0 HO camshaft
~ Stock HO cylinder head
~ Stock 0.051" head gasket
~ 0.097" quench height
~ 2.25" exhaust
~ Ford 24lb/hr injectors with stock 39psi FPR for '87-'95 engines, stock injectors with stock 49psi FPR for '96 and later engines
226hp @ 4600rpm, 304lbft @ 2000rpm
4.6L Low-buck, low CR "rockcrawler"
~ Keith-Black Silvolite UEM-2229 +0.030" bore pistons
~ Increase piston dish volume to 30cc
8.8:1 CR
~ Crane #750501 192/204 degree camshaft
~ Ported HO 1.91"/1.50" cylinder head
~ Mill block deck 0.035"
~ Mopar Performance 0.043" head gasket
~ 0.058" quench height
~ 2.25" exhaust
~ 231hp @ 4400rpm, 327lbft @ 2000rpm
4.5L Low-buck simple stroker
~ Jeep 4.0L 3.875" standard bore pistons
9.7:1 CR
~ CompCams #68-231-4 206/214 degree camshaft
~ 0.081" quench height
~ Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors with stock 49psi FPR for '96 and later engines
~ 260hp @ 4850rpm, 321lbft @ 3500rpm
4.6L Low-buck stroker
Option 1: Same as above except:
~ Speed Pro H825CP +0.030" bore pistons
~ 9.6:1 CR
~ 0.082" quench height*
~ 260hp @ 4800rpm, 324lbft @ 3500rpm
Option 2: Same as "rockcrawler" except:
~ Piston dish volume 22cc
~ 9.5:1 CR
~ Crane #753905 204/216 degree camshaft
~ 2.5" exhaust
~ 256hp @ 4750rpm, 324lbft @ 3500rpm
4.7L medium-buck stroker
~ Jeep 4.0L 6.125" rods
~ Custom +0.060" bore pistons with 1.38" pin height & 25cc dish
~ 9.6:1 CR
~ Ported big valve 2.02"/1.60" cylinder head
~ 0.043" quench height
~ Flometrics F&B 68mm billet TB
~ Accel 26lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Accel 26lb/hr injectors with stock 49psi FPR for '96 and later engines.
~ 270hp @ 4800rpm, 335lbft @ 3400rpm
4.8L medium-buck stroker
~ Custom 4.0" bore pistons with 1.38" pin height & 24cc dish
~ 10.0:1 CR
~ CompCams #68-235-4 210/218 degree camshaft
~ 284hp @ 4900rpm, 345lbft @ 3600rpm
Option 2: Same as Option 1 except:
~ Jeep 4.2L 5.875" rods bushed for 0.912" floating pin
~ Small Block Ford UEM-KB364 hypereutectic pistons
~ Mill block deck 0.015"
~ 0.051" quench height
4.9L high-buck stroker
~ 3.98" offset-ground stroker crank
~ Small Block Chevy UEM-KB142 hypereutectic pistons
~ 10.5:1 CR
~ Crane #753941 216/228 degree camshaft
~ 0.055" quench height
~ 3.0" exhaust system
~ Ford 30lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 30lb/hr injectors with stock 49psi FPR for '96 and later engines.
~ Custom PCM programming
~ 299hp @ 5000rpm, 353lbft @ 3700rpm
5.0L Very high-buck stroker
~ 4.06" offset-ground stroker crank
~ 11.1:1 CR
~ Crane #751111 238/248 degree solid lifter cam
~ OEM 0.051" head gasket
~ 0.038" quench height
~ 328hp @ 5250rpm, 375lbft @ 3800rpm
donc c'est ce que je te dis tu dépassera pas les 250cv ton préparateur t'annonce des cv comme des cacahuettes!!!
si tu as besoin de conseil je suis là ! de plus je suis en train de voir pour faire des moteurs stroker pour la france et pourquoi pas pour l'europe et les distribuer a de super prix (pour l'instant je fait pas de pub c'est en attente)
tu sais la préparation moteur est pas évidente du tout!
ça fait plus de 15 que je prépare des moteurs sur des offshores sur des blocs GM et Ford de 5l à 9.6l de cylindrée avec ou sans compresseur en double carbu ou en injection de 280 a + de 1000cv
et c'est pour çà que te dis qu'une seule mauvaise pièce et c'est tout l'ensemble qui en subi les conséquences (perte de cv et pas le bon couple) :?
A+ DAM.
